Deleting Applications on a Mac
I have a MacBook, but this question is relating to Macs on a whole. I know that when you download an app on a Windows computer you go to the "add/remove" option in the control panel. But normally, when I want to remove an app on my Mac, I simply delete it ; then remove it from my trash can.
Is this the correct way to go by it or is there another method?
