Deleting a backup edition from the Acronis True Image Home 2011.
Hi all.
When I try to delete a backup edition from the Acronis True Image Home 2011. I am getting the following error message:
Failed to open data stream
Error code: 0x000B03E9
I’m not familiar with this error, maybe some of you knows what does it mean. How can I get rid of this? Please help me.
Thanks in advance.
Backup Version Deletion
Are you sure you want to delete the backup version?
Answered By 590495 points N/A #155516
If this is the first time it happened with Acronis, try restarting your computer then try it again. If the problem is still the same on the next attempt, try doing a clean installation of the software to restore it to its default configuration and possibly fix any corrupted files that may have developed in the system in the long run. Uninstall Acronis from your machine then restart your computer when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks or Norton Utilities. Install the program again after this and then check if this fixes the problem.
You may also try upgrading your current version of Acronis to the latest version.
