Hello everyone! I am an iPhone user and I want to delete all the duplicated photos from my iPhone that were actually synced from an old PC. I have actually run out of space because for some strange reason many of my photos have been duplicated and obviously now I don't have the 'delete' option because they were added from my old computer which I longer have in my use. Please help me to get over this problem because now I am running out of memory space/ Thank You!
Deleting duplicated photos on iPhone
You can surely delete duplicate photos one by one but that will not be feasible. Better is to use a tool to do this job for you. Use the tool Wondershare TunesGo software in your PC to perform this job. This software will not delete the duplicate folders automatically. This will show duplicate photo from your iPhone and you need to delete them if you want. Below is the process to delete duplicate photos using Wondershare TunesGo software.
1. Download the trial version of the software Wondershare TunesGo. Search on internet and clicking on first result will take you in the Wondershare TunesGo official website. From there you can download this software depending on your PC operating system Mac or windows.
2. Once successfully installed connect your iPhone with the PC using USB cable and launch the software Wondershare TunesGo. Once your iPhone will be connected successfully your iPhone will show in the software.
3. On the left side of the software click on photos. You will see the photos are saved in different folder like photo stream, cameral roll, photo library. Right click on each folder and select the duplicate photos.
4. Then select the duplicate photos and delete them for each folder.
