Deletion of directly downloaded itune songs from iPhone without using computer
How to delete directly downloaded iTunes songs without being synced from an iPhone?
Is it possible to do this without using a computer?
Without using computer you can delete the songs from iTunes download list. You have to first delete it from iTunes list and delete it from the selected list.
Thanks
You can’t delete songs that came pre-installed with your iPhone but you can always remove those you have purchased or created from iTunes.
There are easy ways of deleting ringtones from iTunes either permanently or temporarily using your computer and not directly from your Smartphone. Try following the instructions below. This example describes how to delete ringtones from your iPhone. Just try adopting this procedure.
For more information you may visit.
