Dell desktop to function with 2 VDUs
I would like my Dell desktop to function with 2 VDUs. One of the monitors is connected to the onboard chip and I also do have a peripheral component interconnect card and it can be identified by the operating system. My computer’s dimension is 3000 and all I need now is an advice on how I can go about to make the monitors work.
Answered By 15 points N/A #109434
Since you already have the hardware to get the setup going, you just need to have the software to get it all configured. You first have to make sure if such a setup is supported by your operating system. If it’s not, try and see if you can find a software to make it work. Most of the time, the graphics processing unit’s software can get it all done and you can configured the setup by using your graphics card’s utility. Also make sure that the driver for your component interconnect card is installed, otherwise it’s useless. If the operating system you’re using does support this feature, then there’s no need for third party software.
