Dell dock crashes and error
I have a dell computer with windows 7 installed on it and other software of dell installed on it, this dell dock like in any mac is causing error on my computer, It always crashes and pop this error but whenever I try to uninstall it, it just hangs.
Dell Dock
There was an error while submitting the error report. Please try again.
Answered By 5 points N/A #145720
Hi there,
seems like your dock is corrupted somehow,
Try finding this directory in your Dell Dock Folder in Program Files:
"C:Users<user_name>AppDataLocalStardock_Corporation"
Remove it, restart your PC and restart dell dock, check if it works?
If no then try these steps:
Go to control panel and "Remove Program" then uninstall completely "Dell Dock", then go to program files and search for any folder named "Dell Dock" remove it permanently from there,
Now go to Dell official site, place your Machine Service tag and download latest updated "Dell Dock" and reinstall it in your system.
Then perform these steps:
Run services.msc
Now look for Dock Login
Double left click on it, check if its set to disabled.
If its disabled, select Automatic on the drop down box.
Then click apply or OK, restart the system
Hope it works!!
