Dell Inspiron 5537 shows limited access although Internet is connected.
I have a dell Inspiron 5537 laptop. It works all fine. From the past 2 days it has been showing a small yellow icon over the internet sign and says that I have limited access although my internet is working fine. What can I do to remove this sign? Is this a problem with my laptop WiFi antenna? Or is it something to do with my hardware driver? Please guide.
Best Answer by Clare Moui
Answered By 0 points N/A #191005
Just Find that your wifi connection is working fine if it is. Then forget the network from your laptop and try to reconnect it again and then if the everything goes ok then fine. Otherwise troubleshoot the problem and it will find the problem and then fix it in. And your problem will be solved.
Answered By 0 points N/A #191004
The Limited access for your WiFi might be because of driver. Your WiFi needs new driver. Update your driver. Make sure that the driver of WiFi version is latest and compatible to your system.
The Limited access for your WiFi might be because of WiFi connection. Off the WiFi connection from your system and then on it again after some time. It might be possible that the antenna is not able to find the server connection.
