I am using Dell laptop, recently my charger is acting awkwardly, it gets heated up very easily and then stops charging, but eventually it again starts charging the battery. I am using the original Adapter with correct Voltage Specifications as mentioned, but still having this issue. What could be the possible reason behind it? Please suggest any fix.
Dell Laptop’ charger behaving as Impotent.
I guess it is obviously a problem with the laptop’s charger. Supposedly, the charger will continuously charge the laptop until the battery is full and will not suspend the charging in the middle and then continue again. If this continues to happen every time you charge your laptop, the charger will eventually wear out soon and will no longer work.
To prevent any damage this behavior can cause to your battery, replace the charger as soon as possible. It is not good to have an interruption when the battery is charging. Maybe it’s fine if it happens infrequently but if it happens all the time every time you charge the computer then it’s not good.
If your charger heats up very easily even if you just started charging it, it’s a great risk for burn.
