faizi
10 points
Posted on - 09/27/2011
Guys i have Dell Optiplex GX280 which have a problem of processor overheating.The circuit does'nt break which results in short-circuiting due to which my hard disk loses all the data.
Please if anyone know how to save my hard disk tell me……….
Anthoino
Dell Optiplex gx280 processor overheating
you mean did you lost your hard disk by physical damages or your data lost and hard is working ? or both
try to attach your hard disk to another computer. and then if your hard disk is not physically damaged and you cant see the data from the other computer you can just use a recovery software and recover you lost data
if you have hard disk is physically damaged. you better go for a professional hard disk data recovery company or to a recovery technician, i can surely say that it will cost high depend on your damage level. but hope for the best.
first please attach your hard disk to another computer by using another data cable. because due to reasons that you have explained its better to use new data cable and check
thanks
