Dell Resource CD Download Freeusing Some Simple Steps
Hi. I have recently bought a Dell laptop. I would like to know the steps to install the Dell Resource CD download free. Please reply ASAP. Thanks in advance.
Hi. The steps to install the Dell Resource CD download freerequire you to first insert the Dell Drivers CD/DVD and then click on next. Next, click on run and then select the driver which you want to install. Next, click on the extract option and then continue after the extract pop-up appears on the screen. Next, click on the folder which you want to install and in case the folder does not exist, then click on yes. Wait till the extraction gets over. Next, when all the files are zipped successfully, then click on OK. For the drivers, follow the InstallShield wizard and then make sure that all the drivers have successfully been installed by checking the device manager.
Alternatively, log onto the website of Dell and browse the page, select the driver and downloads option. Next, select the drivers and downloads home, then choose the list of Dell products and click on continue. After that, select the product for which a driver is needed. Then, locate the product which you want to install and then download the file which you want to download.
Hope we helped.
Notifications
