My Dell Streak 7 is stuck at the logo screen. I tried to reset it by pressing the pin hole near the sim card using a paper clip. I tried everything I can find from the manual but nothing seemed to help. What else can I try to do to fix this problem?
If you have a Dell Streak 7 tablet that got stuck on the logo, you have a similar problem with another user. One user has this tablet and it suddenly restarted. Like with you, the tablet got stuck on the logo when it was booting. The user tried to call for Dell technical support but all they suggested was to do a factory reset.
Dell Streak 7
The suggested solution was a total failure. Every time the tablet had a factory reset, the screen would just keep flashing. The user tried to connect the charger and charge the tablet until it was full. When the battery is fully charged, a pin was inserted into the reset hole then pressed and hold the volume + and power buttons simultaneously.
The user finally able to get the factory reset command screen. Now, since you have the same problem, try following these steps to get to the factory reset command screen then factory reset your tablet. See if this works. Here are the tablet’s specs. The Dell Streak 7 is a discontinued 3G tablet operating on 2G and 3G network bands using GSM and HSPA technologies.
It was unveiled to the public on February 2011 and released on March 2011 measuring 200 x 119.8 x 12.4 millimeters and weighing 453.6 grams. It uses mini-SIM card and has TFT capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass.
It ships with either Android 2.2 Froyo or Android 2.3 Gingerbread upgradable to Android 3.2 Honeycomb powered by NVIDIA Tegra 2 T20 chipset, 1 GHz Dual-Core Cortex-A9 processor, and ULP GeForce GPU. It supports microSD expandable up to 32 GB. It has 16 GB internal storage. The primary camera supports 5 megapixels with AF featuring LED flash and supports 720p video recording.
The secondary camera supports 1.3 megapixels. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 2.1 with A2DP and EDR support, GPS with A-GPS support, and USB 2.0. It doesn’t have FM radio. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support.
It runs on non-removable Li-Ion 2780 mAh battery with standby time up to 72 hours and talk time up to 4 hours. It is available in gray color.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
