Hi to everyone,
Dell xps 720 quick set is not working anymore. I’ve been performing some update with my windows 7 starter operating system and suddenly noticed that I cannot make use of controlling the lights of my xps 720. As a gamer I want those feature back in my dell computer.
Thank you.
I recommend you to run System Restore. It is a recovery tool that helps you to undo changes through the OS. It is an "undo" element for the largest significant components of Microsoft Windows. Used to return essential settings and files, like system files, registry keys, drivers and installed programs, reverse to earlier settings and version. It is considered as a step by step wizard. Make it really simple to decide a point in the history, called a restore point, to revisit your vital settings and file.
Best regards,
Heather marie
Hi Curtis,
     Dell Quickset is one of the few problematic tools in Dell computers. Here is what you can try to do: Make sure that the Dell Quickset is enabled in Start up programs this ensures that it opens automatically at startup. You can also try to repair the program to enable any files from the software. If all else fails, then you can just reinstall the program to correct all problem.
