Delphi print a file to a USB websites.
I was wondering if someone will list some Delphi print a file to a USB websites for me. Any kind of help would be appreciated.
Hi Hollis,
Printing a file to USB using Delphi is quite simple.
1. First connect the USB to your PC and see if it is being detected by the system.
2. Now open Delphi and go to the file you want to print.
3. Use ctrl+P. A new window should come up and then click on ‘save’ to disk, browse and selection the location you want to save the file in.
4. Then transfer the file to your USB. Isn’t it simple? Even though I have described the method to print a file to USB using Delphi, I would like to give you links of a few websites that will give you some extra information on this topic.
Hope this helps you.
