When using a Delphi programming language can we print a file to a usb(universal serial bus)? And tell me more about Delphi programming or any website that offers a tutorial for free. I need your help experts.
Delphi program can print a file to a USB?
You can print a file to USB using Delphi programming language. Firstly, connect the USB to your system. Make sure that your USB is detected by the system. Now run Delphi and go to the file that you want to print. Press Ctrl+P on your keyboard. A new window will appear, click save to disk. Then select the location as your USB. You can also save the file to your system and later transfer it to your USB.
There are many websites which provide the Delphi programming language tutorials. The following are some of the websites that provide tutorials:
1. About.com – https://www.thoughtco.com/beginners-guide-to-delphi-programming-1057657
2. Delphi basics – http://www.delphibasics.co.uk/
3. Delphi central – http://www.delphi-central.com/.
