In demand and easy to use Programming Language
I have a problem on deciding on what programming language to use for our project. Can anyone help me on choosing what programming language is easy to use and is in demand in the technology world?
Hi Abel,
Deciding the right programming language could depends your organization. For my opinion .NE programming is one of the top technology in the market. The thing is, you have to spend lots of money for your software. Another factor to be considered is the willingness of your team to adapt the new technology. Most of the people likes open source programming language like Java. Another thing to consider is the type of project you are planning; a desktop application or a web base application. You also have to consider the target system of your project and the size of the project. If your project is huge, managing it would be easier using .Net. Note that all I said here is based on my personal opinion and experience.
I hope it helps.
