Hello guys,
I was trying to deploy a standard server on my computer.
Everything goes smooth up until the last phase that is the activation phase, and I get the following error during this step.
I have no idea why this is happening.
Can anyone help?
Deploy Server Wizard
Deploy Server Wizard has failed.
view the log when you click Finish
Finish
Deploy Server installation failed in activation phase
To deploy a standard server on your computer you must install OCS 2007 R2. From your question I ensure that you have faced problem in last option where is an alert that says deploy server wizard has failed. We may follow two-step again to solve the problem.
1. Click the finish button and we will get the new idea about error code.
2. Check the event log file and update again from Microsoft support center.
By using this technique you may solve it easily. If you fail after downloading the update, you must contact with Microsoft for the best use.
