Deploy software update wizard access denied
Hello all
I was trying to install the software updates, but I was met with the following error.
The screenshot of the error is as follows:
 The message states:
The download software updates Wizard completed with errors
Error: Access in denied.
I have checked all the permissions that are absolutely correct. I've also managed to create a share in the same folder structure for Endpoint Definition Updates, so the process worked previously.
I don’t know where I am going wrong. Anyone can please guide me how to solve the issue, I'll be grateful.
Looking forward to your suggestions.
Regards.
