blainea
Posted on - 11/03/2011
Hello!
Anyone who has successfully deployed Lotus Notes 8.5 or 8.5.1 on XenApp 4.5 or 5.0? I am aware Notes is solely "supported" on XenApp 4.5. I am yet to have a breakthrough in our test lab. I am at the moment on Windows 2003 x86 w/SP2 XenApp 4.5 RP3
Please guide me.
Thanks…
Deploying lotus to xenapp problem
Hallo Blainea,
That is an issue most likely has to do with the Citrix environment, but in case Lotus Notes will not be able to support your configuration then going on with the process might be a little hard. What you will need to do is contact Citrix customer support to get assistance from them concerning the issue.
Nicke
Hello Blainea,
If you want to use the Lotus notes on XenApp then you have to see many things for that. You have to test your connection so that you can get your work easily. After that you also have to check for your errors that may come in your connections. I am giving you a link from there you can get a complete pictorial guide on how to install and deploy the applications for your use. Here every thing and all possible errors are also explained for your convenience.
https://www.ibm.com/developerworks/lotus/library/notes851-travperf/
