Deployment summary error applying image from setup
Hi there,
This is the error that I have when I want to install ZTI on my PC. I had to reinstall the program because I made some updates of my Windows and it didn’t work after. Can anyone help me please to fix this error?
Thanks !
Setup failed applying image\MDT2012DeploymentShare$Operating SystemsWindows
Server 8 Beta SERVERSANDCORE x64Sourceinstall.win.rc = 31
ZTI ERROR – Non-zero return code by LTIApply.rc=31
Litetouch deployment failed. Return Code = 2147467259 0x80004005
Failed to save envirnments to (80070057)
Failed to run the action: Install Operating System.
A device attached to the system is not functioning. (Error: 0000001F: Source: Windows)
The execution of the group (Install) has failed and the execution has been aborted. An action failed.
Operation aborted (Error: 80004004:Source: Windows)
Failed to run the last action: Install Operating System Execution of task sequence failed.
A device attached to the system is no functioning (Error: 000001F: Source: Windows)
Task Sequence Engine Failed with error code 80004005
Error Task Sequence Manager failed to execute task sequence. Code 0x80004005
Finish
