The motion sensor from SoftKinetic made waves in the recent Computex. The motion sensor is a lot smaller than the old releases of the company. Does DepthSense 325 offer HD that is good for gaming and video conference?
Is DepthSense325 from SoftKinetic will show HD in full mode?
Hi Natanne
SoftKinetic DepthSense 325 will work with SmartTV. In addition to its HD ability, The DepthSense 325 is perfect for playing games, video conference, and other PC applications.
More features that will amaze you further are:
DepthSense 325 can operate as close as 10cm and it has high-resolution depth sensor plus HD Video and 2 microphones. Â The minimum focus distance is 3.94 inches. The dimensions are 1.22 inches (h), 4.13 inches (w), and 1.06 inches (d)
A small device that has a lot of features, it’s really worth the price. The original price for the DepthSense 325 is $249.
Hope you will find this helpful.
Cheers
