Describe about Sony VPL EX272 LCD Projector
Has this projector auto power saving function? What is the dimension available? What is 3LCD display system in it? What are the connectors available on it? Is there USB type C port? How is it different from Sony VPL SX235 LCD Projector? Describe about its light output. How is it Life of Lamp capacity? How is its audio output system? What is the actual resolution on it? Can I adjust the resolution? Describe about its Projector Lens. Have these any additional features? Thank You
Answered By 0 points N/A #171682
                The vpl ex272 data projector is designed optimum energy efficiency and very thanks to auto power saving with lamp technology long lasting camp and light lamp control technology.
                The variety of web control and network function can be performed clearly. There are rich input and rich output to suit a broad range of applications.
                The vpl ex272 has provided high quality pictures in xga resolution with brightness up to 3700 Lumens. It delivers simple operation and quality and cost education or business with this modern technology.
