Describe Error Code 0x80070057
Why am I getting an error code 0x80070057 while taking Backup of my system files? Does anyone know the reason of this failure? Please tell me how to fix it.
It occurs while taking Backup because there is something that might damage the reserve partition of the system.
There are many ways to fix this problem. You can check the below methods:
Receiving error code “0x80070057,” according to Microsoft, indicates a problem with the system partition which is used for BitLocker and system restore. The error is triggered because the system partition is damaged. You may also receive this error when copying files and that’s probably why you receive it because you are backing up some files.
The best remedy is to create a new system partition. In Windows XP, when you install the operating system, setup will create only one partition for the system drive where Microsoft Windows will be installed while in Windows 7, setup will require you to create two partitions: one for the system drive where Windows 7 will be installed and one for the reserved system partition which is used basically to restore the operating system and for BitLocker.
To help you properly create a new reserved system partition, go to Windows 7 System Reserved and follow the guide.
