Describe McAfee Dlp Endpoint Uninstall Password Generator Process
How to remove the McAfee antivirus from the system? Can anyone tell me how I can use McAfee dlp endpoint uninstall password generator? Please tell me how I can do it.
There are a lot of ways to perform this action. You cannot remove it by uninstalling from the control panel.
Check the below methods and try them on your system.
1. Open run prompt by Windows key + R and type “Regedit.”
2. select Current Control Set and in its services.
3. Search for McAfee dlp and select it.
4. Find Agent Service, fcdrv types and Frame Network. Double click on them one by one and change the value with 4.
5. Restart the machine and then uninstall them by going to Control Panel then uninstall a service.
If you find the above process complicated, then download the McAfee Removal Tool and run it.
It will do that process automatically.
If you want to remove your McAfee antivirus, the easiest way is from the “Add or Remove Programs” applet in the Control Panel. This will uninstall the program from your system but may leave some leftover files like temporary files and folders, registry entries, undeleted files in the installation folder, and others. This is normal, actually, for most programs.
But if you want to completely remove an application without leaving a single trace behind, download Revo Uninstaller. Follow the instructions to download and unpack and then install it. Once installed, start Revo Uninstaller then select McAfee antivirus from the list. Click “Uninstall” then follow the instructions to perform a complete removal. The process includes scanning your computer for possible remnants after the program has been uninstalled.
You will then be given an option to delete the leftover data to remove everything the program created on your computer. You need to select all and delete them.
