Describe Sony Ericsson J10i2 Software Update Process
I have a Sony Ericsson j10i2 phone. I was trying to upgrade its firmware version, but I do not know how to do it. Can anyone tell me about Sony Ericsson j10i2 software update?
You can update your handset by using below method.
You have to download Update Application of Sony Ericsson to perform that task. You can get it from here.
Be sure your phone has battery above 50%. You need a data cable to connect your phone.
Now, switch off your phone and connect it to the system.
Run the software and hit the necessary action to update the phone.
If you have a Sony Ericsson Elm J10i2, you need first to download and install Sony Ericsson Update Service. Once it is installed, connect your phone to your computer via USB cable then run the Sony Ericsson Update Service application. Select your phone model from the application and the program will detect the latest software for your handset.
Before you do this, make sure your computer is connected to the internet. According to the website, Uptodown.com, this is the official program developed by Sony Ericsson to update your mobile phone. Also, I don’t think you will still be able to download it from the official Sony website. Anyway, here are the specifications of your phone.
The Sony Ericsson Elm is a discontinued 3G mobile phone operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on December 2009 and released on March 2010 measuring 110 x 45 x 14 millimeters and weighing 90 grams. It uses mini-SIM card with splash resistant. It has TFT display with 256K colors at 240 x 320 pixels screen resolution.
It supports microSD expandable up to 16 GB with 280 MB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus featuring video calling, geo-tagging, and face and smile detection and supports video in 480p at 30 fps. It doesn’t have a secondary camera.
It has Wi-Fi 802.11 b/g with DLNA support, Bluetooth 2.1 with A2DP and EDR support, GPS with A-GPS and Wisepilot navigation support, stereo FM radio with RDS support, and USB 2.0. It doesn’t have 3.5-millimeter jack. It has built-in accelerometer sensor. The preinstalled web browser supports WAP 2.0/HTML (NetFront) with RSS reader support. Java is supported via MIDP 2.0.
It runs on removable BST-43 Li-Po 1000 mAh battery with standby time up to 336 hours on 2G and 424 hours on 3G. Talk time is up to 4 hours 30 minutes on 2G and 3 hours 40 minutes on 3G. It is available in metal black and pearly rose colors.
