Description Of MSOffice 2010 Language Pack Sp2
HI, I’m getting a Microsoft update as this service pack 2 of office 2010 language pack. Is there any problem if I install this update? Needed a help regarding this and steps to install this. Thanks in advance.
Image result for MS Office 2010 Language pack
Answered By 0 points N/A #294772
MS Office 2010 language pack service pack2 provides the latest updates. This fixes improvements in stability and performance also improves security features.  So there is no problem if you install this update. In fact it is goodyou can install this services pack from Microsoft update.  Method two is downloading support package from Microsoft download center (MSDN) directly. If you download directly from download center check your system is 32 bit or 64 bit then install the corresponding file.
