Description of server settings for office 365
For server settings for office 365, you can access your email using a mobile device or software like Microsoft Outlook, you’ll need to make sure that the settings are correct. If they’re not right, your email won’t work.
If you already know how to check your settings and you just want to know what the server details are, then, see below:
Server details for Office 365:
IMAP setting-
Server name: outlook.office365.com
Port: 993
Encryption method: SSL
POP setting-
Port: 995
SMTP setting-
Server name: smtp.office365.com
Port: 587
Encryption method: SSL/TLS
SMTP authentication: ticked
Authentication: your password
