Hi Experts,
I received an error message on my laptop running with Windows Vista 32-bit and 4 GB of RAM.
I did not use any additional graphics card for my laptop. Have a look at the error message below. What does it mean?
Please help me to solve the problem.
Thanks in advance.
Exception
Art/Texture/Environment/forest/mossanotherns.dds”:In source code file: ResourceTextureResource.cpp at line 37,
Processing file: Art/Texture/Environment/forest/mossanotherns.dds
Error: E_OUTOFMEMORY
Description: Ran out of memory
Hello Jhon,
Your computer is possibly running on very low memory, and therefore you will need to free up some more space on your primary partition to in order to increase the memory that is available. You can as well go to the device manager and update the graphics and see if that will resolve the issue.
Nicke
Please check out for hard drive partitions and the remaining free space on Drive C. You should have as much as free space on your C drive and a handsome RAM in order to run the software seamlessly. Delete some unnecessary file; shift your pictures and other memory consuming programs to your other partitions.
