Desktop Computer display hardware problem
How do i enable onboard video card through cmos bios because i accidently go to my video setting properties on my windows and disable it and  now cant see anything once windows load up?
Hello Anser,
Onboard Video card in your computer is not working and of disabled, below are the steps to fix.
These steps should let you fix Onboard Video Card without help by someone else’s computer savvy.
Please do restart your computer. Hit the function key that enables you to enter the BIOS setup. Look for Boot section tab and restore default. It will let you notified when you exit this BIOS setup and save it. Instantly the default values for this problem will be resolved.
Hope it helps.
Dlanear-
