Buddy Smtih
Posted on - 08/24/2011
I'm having a problem with my desktop icons. When I double-clicked them, I get the error message below.
Windows Explorer
Windows can't find '%SystemRoot%'. Check the spelling and try again.
I tried to run a disk check, ran a full system scan using my Antivirus software and even running a System Restore but it didn't work. I'm planning to reinstall those programs but it will take my time and I found it inconvenient.
Any suggestions guys?
Thanks,
Buddy
jhonkemp
Desktop shortcut icons not working
This problem is because you don't have unset the systemroot. to fix this problem you should have to add it '%SystemRoot%':. Manually. the procedure to add it is as below.
If C drive is your main drive C:windows and not to use slash as you are administrator to the system.
you can also do this using command prompt. the command to set you %systemroot% variable is given below.
set SystemRoot= your main drive full colon and Windows this will set you SystemRoot environment.
If you are still facing the problem after applying these steps, do inform me.
Thanks
Jhonkemp
This error message means the system cannot locate this file "%systemroot%", the command is not valid. The software is corrupted and can't specify the location.
You may try if this file is correct by testing in the Run window.
Go to Start, click Run and type this command: %systemroot% and press OK
After pressing the Ok button, a window will pop-up if the file is found or not.
To help locate this file, you may try going to your c: drive
Try this command in the Run box, C:WINDOWSSystem32
If you are re-installing your windows, try this command;
c:(your installation folder)
Run the CD and you may proceed on the installation.
