Desktop showing problem after shutting down
I am a new user posting my first question.
Motherboard: Intel D914PDT
Processor: 3.4 GHz
RAM: 2GB DDR1
The problem is that when i shut down my pc, i can not start my pc after that. I have to wait for a day.
After a day i can restart my pc. I installed several operating system.
But none worked. Need solution ASAP.
Answered By 0 points N/A #127690
Hello Robert,
It seems that you need to sleep first for a day before you can use your computer, huh? That’s for is time consuming. Not unless you want to wait until the next day just to let your computer reboots that long. Which I am sure you won’t do it. If you have to then go on, nahh! I’m just kidding.
Now, this problem is a little broad. I have no clue where to start, what the main problem of that computer of yours. But I will give possible reasons and solutions for long term fix.
Possible problem is:
I may say that the problem might be on the Net BIOS itself. Computer can’t reboot the normal way because of missing components and of corrupted hard drive. It may vary on different reasons;
  1. Low memory, RAM
  2. Virus infection
  3. Corrupted Operating System
  4. Hardware problem, part of motherboards and or fan
  5. Observe if it beeps when re-starting
Beeps
Meaning
1 long, 2 short
Video adapter error: Bad or improperly seated video card
Repeating beeps
Memory error: Bad or improperly seated RAM
1 long, 3 short
Bad video RAM or video card not present
High-frequency beeps
Overheated CPU: Check fans
Repeating high/low beeps
CPU: Improperly seated or defective CPU
Computer reformat is the best solution.
