anonymous
7060 points
Posted on - 09/26/2011
When report print detail lines onto 2nd page — I want the printing of the detail lines to start on the page 2 where they started on page 1 — Instead the lines are printing on page 2 at top of page — Overwriting preprinted heading —
How can I force it to begin printing at same location as page 1
Phoebe14
Detail Lines printing on second page
I see that you pre-printed a heading on a sheet of paper and would like to print the content. You should edit the text on page 2 then, consider how big the heading is and then press the Enter button on the very first line of page two so that you will have enough space for the text and the heading to avoid overlapping. Next time, consider if you are using the Header/footer Options for your details per page, it should be pretty simple. You can go to the View on the Menu bar and click on Header/Footer. The Header/Footer window pane will appear and you can edit the header to make sure that it does not overlap with the text itself. Using a header will make you sure that the format of the details you put on the top page will be the same for every page.
