Details about the using iperf to test throughput in stepwise.
Hey,
Notify for the using iperf to test throughput and the steps for the same as well and thanks for solving the same too and revert asap.
Hey,
Hey,
The using iperf to test throughput is used to calculate the TCP and the UDP performances. Also it looks over its characteristics too and performs a number of test too like its bandwidth jitter and many others too. Below shows its steps too:
• First install the iperf from the iperf source packages manually.
• Also later add the normal source installing
• Also can get the installing link for it too
• Now configure the options with the extracted directory too.
• Now compile the same and install the commands as well.
