I am interested to buy a new Toshiba Portage R835, but I have some doubts on its specifications.
I want specifications that company offers.
Which is the category of this laptop according to Toshiba ?
How much weight does it have ?
How much is the basic price of this laptop (In India) ?
And also I want to know the chipset used in it by the company.
Details about Toshiba portege R835
I believe you’re referring to the Toshiba Portege R835, It’s designed for business use like most Porteges are.
The specifications are noted below:
Processor: Intel Core i5-2410M.
Chipset: Mobile Intel HM65 Express chipset
Video Card: Mobile Intel HD Graphics (this has 64MB-1696MB of memory allocated for the graphics alone which makes it faster.).
Screen: 13.3″ widescreen HD TruBrite LED Backlit display which includes Intel Wireless Display Technology.
RAM: 4GB DDR3 1333MHz.
HDD: 640GB HDD (5400rpm): You can also opt for a 7200 rpm, that’s faster.
Optical Drive: DVD-SuperMulti drive (+/-R double layer).
Media: Webcam and microphone.
Wireless: Intel Wi-Fi Wireless networking (802.11b/g/n + WiDi Capable).
Ethernet: 10/100/1000 Ethernet LAN.
Ports: 1-eSATA/USB (2.0) combo port with Sleep and Charge, 1-USB (3.0) port, 1-USB (2.0) port.
Battery: Li-Ion (66Wh, 6-Cell) battery.
Weight: Starts at 3.2 lbs
Price in India: 43,000 – 56,000/- INR (shop around for the best deals)
Usually there are options to upgrade features like the RAM, HDD and battery.
It’s always best to call them but you can try the Technical Support department first if you want to be sure.
