Alex M Hung
Posted on - 03/25/2017
Hello, notify the list of various methods for c0000221 unknown hard error systemroot system32 ntdll.dll and also brief for the same with its details as well with its steps one after the other for the guidance too and thanks a lot too.
Details For C0000221 Unknown Hard Error Systemroot System32 Ntdll.dll In Steps.
Hey, the c0000221 unknown hard error systemroot system32 ntdll.dll will occurs if the windows systems is corrupted try uninstalling the same and add a new systems too it if still not solved try for the below steps one after the other.
- Can return the systems with the Ram configurations too
- Later recover the console too and delete the pagefiles.sys as well
- Now recover the console by chkdsk/r in the run box
- Now restart the systems too
- Next set the page file for the RAM added as well
- Next shutdown the systems as well
- The new RAM will match the speed and parity as well and it’s completed as well.
If you receive that error in Microsoft Windows but not with a particular program, restart the computer and try again. If this doesn’t work, try using the System File Checker utility. Press the Windows key + R to bring up the “Run” dialog then type without quotes “sfc /scannow” then hit Enter. Insert your Windows setup CD or DVD when you are prompted.
Wait until the process is complete. When it is finished, restart the computer. The “ntdll.dll” file is a module in Microsoft Windows containing NT system functions with a description of “NT Layer DLL”. It is the file that contains NT kernel functions. The “ntdll.dll” file is located in the following locations:
- C:\Windows\System32
- C:\WINNT\System32
- C:\i386
If you receive that error while using Microsoft Internet Explorer, you may fix the problem by removing third-party add-ons in the browser.
