Details For The 3ds Error Code 001 0502 In Stepwise
Hello, details for the 3ds error code 001 0502 and notify the steps for the guidance too also reply soon and thank you very much as well.
Hey, the 3ds error code 001 0502 mainly deals with the connection to one device to other. This type of error may occur if it’s not connected to other device and will prompt the error as well. To solve the same follow below steps too:
You normally get error code “001-0502” when playing games online with your Nintendo 3DS. When this error occurs, you won’t be able to connect to the “Friend List”. This problem is often caused by your Wi-Fi router or home network that is blocking the traffic needed for the “Friend List” feature. Here’s what to do when this error hits you.
Try restarting your Nintendo 3DS. First, on your Nintendo 3DS press the power button. Next, tap the power off button at the bottom of the Nintendo 3DS touchscreen. After this, press the power button to turn the system back on. Next, try using the online feature again and see if it works. On the other hand, if the problem continues, try forwarding these UDP ports to your router:
Before forwarding the ports to your router, you need to manually assign an IP address to your Nintendo 3DS Internet settings. Visit How to Enter Network IP Address for the guide.
