Details of Microprocessor for the project work
I have to make a project on microprocessor. Can any one mail me the details, anything that can help me out?
A microprocessor is sometimes called a “logic chip”. So, basically, it is a computer processor on a microchip or a processor built into a microchip. A microprocessor has the majority, if not all, of the CPU or Central Processing Unit functions. The microprocessor is also the “engine” or the “mechanism” that goes into motion the moment you start your computer.
It is designed to perform arithmetic and logic operations that use “registers” or small number-holding areas. Normal operations that a microprocessor performs include adding, subtracting, fetching numbers from one area to another, and comparing two numbers. When you start or turn on your computer, it is the microprocessor that gets the first instruction from the BIOS or the Basic Input/Output System.
The BIOS is part of the computer memory.
