Belphoebe
Posted on - 11/18/2011
Hi, may I ask for your advice please. What is Windows Installer v4 technology? Is it available for Windows Vista, or with any other programs, so that I won't need to buy anything? I wish to install it in my computer having software of Windows XP. Do I need to have a separate installer? Do I have to use Vista? I wanted to make sure, whether, Vista will identify the Executable set-up software program. What should I do? Thanks.
Details of Windows Installer v4 technology
Windows installer is the best software to install and uninstall the soft wares in your computer. It will give you various feature like – Custom action execution on update uninstall, Multiple package transaction, Embedded chainer, Update supersedence resiliency, Embedded UI handler, and so others.and for removing your confusion windows installer V4.5 is now available which suits all the OS version. Just you have to download it with the Microsoft.com and select the version of your installed version of OS.
Hi there user:
Definitely you can install it to your Windows Vista.
Windows Installer (for al OS) is an installation service and configuration service for all the purchased and built-in applications. It has, a.) Custom Action Execution on Update Uninstall, which able to add or change a custom action when an update is uninstalled, b.) Shared Component Patching Resiliency During Uninstall, which makes sure that the previous version of software is available to all.
Thanks for posting you query.
Best regards,
