Detect hardware in vb6 project
I have a provision I feel a distinct desire to detect hardware in VB6 project, ensure by needing my users to enroll. I moreover prefer to guarantee that they lack the capacity to establish on more than two machines. To do this I ought to know where to recognize a novel fittings ID number, and use that in the enrollment code.
All I ought to know is the way to get that number utilizing code.
Answered By 5 points N/A #132676
To access the computer hardware configuration you can use the FileSystemObject and iterate through the list of hardware information. Check the below link for more details.
http://www.vb-helper.com/howto_net_get_drive_information.html
If you want to access a hardware component which is plugged into your computer system you need to get some specific information from the hardware vendor otherwise it’s not possible to access a hardware device and change its activities.
Programming will be totally different depending on the type of hardware and the vendor of the hardware.
