I have a lot of customers using web – based email address.
Some send me mails of encouragement and some are just too damaging for my career.
Is there any way I can detect someone using web-based email like Gmail, Yahoo, Zoho, etc.
Its IP address so I can report them for spamming?
Detect IP Address of Someone Using a WebMail
The IP address is generally found in the headers for instance, [002.137.1.1] headers are always delivered along with the message contents.
Most email clients provide an option to enable display of these headers if desired.
STEPS TO TRACK THE I.P ADDRESS OF THE SENDER IN YAHOO MAIL
Login to yahoo mail account
Click the Inbox or any folder that contains your incoming emails.
Open the email you want to find the sender I.P
Scroll down, there you will see Full Headers Link below.
Click on that link and this will open the Header Information of the sender.
Here you will see X-Originating-I.P which contains the I.P address of the sender in square brackets.
Visit any I.P address tracking site like
Enter the I.P address and track to find the ISP and location of the sender.
See the attachment for images.
It is possible to find the IP address of sender as it concern web based email services such as Gmail, Yahoo, Hotmail, Zoho etc. Tracking the IP address of an email sender does require looking at some technical details.
There are basically two steps involved in the process of tracking an email. Find the IP address in the email header section and then look up the location of the IP address. You need to look out the lines of text that start with "Received from".
It might be easier to simply press Ctrl+F and perform the phase you search for. Message header contains the IP address.
