Detecting and repairing Disk errors
Hi Friends, I am using Windows XP and I need to know about how to use Error-checking tool that will help me in detecting and repairing Disk errors, Please do the needful for providing me the step by step of using the same. Thanks
Answered By 0 points N/A #198735
Before runing the Error Checking utility, firstly you have to close all open files and then follow these steps:
1> In the My Computer window,right-click on the hard disk that you want to search if there are broken sectors , and click Properties.
2> When Properties dialog box is open,search and click on the Tools tab.
3> Choose the Check Now button.
4> In the Check Disk dialog box,select the Scan for and attempt recovery of bad sectors check box,and then click Start.
5> If you found bad sectors choose to fix them with fix button.
