To Determine The Latest Dot Net Framework Version Installed.
A. Meyers 15 points N/APosted on - 10/13/2016
Multiple versions of dot net framework can be installed in a single machine. The version should be known at the time of development of an application. How to determine the latest dot net framework version installed?
.NET framework has the following components:
1) Group of assemblies that provide the apps with functionality.
2) Common language runtime to manage and execute the code. To find the version from the registry:
1) Open start menu and search run. 2) In the search field type regedit.exe.
3) You will be redirected to Registry editor.
4) Type in the subkey as shown
‘HKEY_LOCAL_MACHINESOFTWAREMicrosoftNET Framework SetupNDP’ If you find DWORD value name as Release then .NET framework 4.5 or newer versions are installed. Depending upon the value of DWORD, version of the framework is decided. Some of them are shown below:
For 378389: .NET Framework 4.5
378675: .NET framework 4.5.1 with Windows 8.1 or Windows Server 2012 R2
378758:.NET Framework 4.5.1 with Windows 8, 7, SP2
379893:.NET Framework 4.5.2
393295 & 393297: .NET Framework 4.6 You can use Raymondcc .NET detector to find the version.
Download the software from the net.
Run the extension.
It will automatically show the frameworks installed with dark color and the uninstalled with light grey color.
When you click on any uninstalled one, you will be redirected to the download page.
That’s right. Regardless of whatever version you have, you can install another version of Microsoft .NET Framework without conflicting with the other version. Install Microsoft .NET Framework only if an application is requiring it. If you don’t need it and no application requires installing it, don’t install it because it’s a waste of space and computer resource.
There is no shortcut when you want to check the latest version you have. You need to do the checking manually from the Control Panel. Click “Start,” “Control Panel,” and then “Add or Remove Programs.” In there, scroll down and look for “Microsoft .NET Framework.” If you have multiple versions installed, you will all see them on the list.
Microsoft .NET Framework installation
Before installing Microsoft .NET Framework, make sure you have a supported operating system because every version requires certain versions of Microsoft Windows.
RICH Miner officially launches a new mobile cloud mining application, subverting the traditional mining model! No need to buy mining machines, no technical experience required, just a mobile phone, global users can start the...
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
