Determining the kind of memo information in an ASP web page?
How do you determine the kind of memo information in an ASP web page as variable? And I want to position that varying in HTML's textual articles position as its value?
The ASP webpage will have to be used with a variable that holds a particle value. Means that a variable has to be chosen that will hold the value. This value will be used to keep the Memo. Then that value has to be sent to a dynamically generated webpage. This webpage can be generated with all the code of HTML as a dynamically created code.
In other words, you can do this by passing a data called memo using the XML file in hand for the transfer for the server to the client. The best way now to do is ASP.Net.
