Determining my Internal Memory of my Hard disk
Hello guys!
I don't have enough knowledge on using computers so I came here to ask your help.
How can I determine the internal memory of my harddisk?
Hello guys!
To determine the internal memory of your Hard Disk (HD) you can go through the following:
1. Go to Windows Start button › Settings › Control Panel. Control Panel window will open.
2. From Control Panel window double click on Performance and Maintenance.  Under Performance and Maintenance window double click on Administrative Tools. From Administrative Tools window double clicks on Computer Management.
3. It will enable to run the computer management tool. Then follow the left side list of this window and select Storage. Below the selected Storage you will find Disk Management. Click it.
4. From the right side of the same window you will see the Disk, its memory, partition etc. It also shows your other drivers.
I hope you understand it.
Thanks
Oh great thanks!
Another addition to my knowledge on computers.Â
Thank you so much expert.Â
Techyv has a lot of information shared.Â
yay!
