Device driver Mac mini Server Windows
Hello techyv experts!!!!!!!
I am using 2007 Macmini 2, 1. I have installed windows 8 on my mac mini . But no audio can be heard. I think it is a problem of device driver mac mini server windows. Does anybody know what audio device driver is needed for me?
Answered By 0 points N/A #132425
From your description I come to know that you are facing a problem for using audio driver in your mac-mini pc.
You use windows 8 currently.
Normally Windows 8 can update audio devices automatically.
But it may be happens for some sort of technical problem.
You can try again with RealtekHigh Definition Audio Driver version 2.49.
After download the new one you have to remove the previous audio driver and restart your computer.
Now install the new one.
Hope your problem will be solved soon.
