Some issues occurred after I installed Adobe Type Manager on my Windows XP machine. I installed an Adobe Type Manager with version 4.0.
"Device Driver for the Standard 101/102-Key or Microsoft Natural PS/2 Keyboard" Error Message When You Try to Enter Standby.
I presume that my Adobe Type Manager is incompatible with my installed OS but that is only my presumption.
Your perception is totally right and you reached the right way. I have quite a keen solution for your problem
This issue might possibly occur if an Adobe type Manager is installed on your computer many of the Adobe Type Manager is quite supportive for your computer on your Windows XP.
To fix this problem try these steps:
Go to start click add/remove programs from the control panel.
There is a box of currently installed programs, click Adobe type Manager or then click remove.
Follow the instructions which appear on your screen to complete the process.
Restart your computer.
This will surely help you to find the solution for your system.
Yes, you are correct. The error you stated occurs when there is Adobe Type Manager installed on your PC. Some Adobe Type Manager versions are not compatible with Windows XP power management features. So you will need to uninstall Adobe Type Manager. Just click on Start and then go to Control Panel. Click Add/Remove Programs. Locate the Adobe Type Manager and then click Change/Remove or Uninstall Program. Just follow the on-screen instructions and then restart your computer.
