jackborn301
Posted on - 12/15/2012
What is Device Manager in Windows 7 and uses of device manger?
Device Manager and its function on Windows 7
A device manager is a software package (typically an .exe file installed by an .inf file) that allows Windows 7 to communicate with a specific hardware device.
Before Windows 7 can use new hardware, a device driver for that hardware must be installed.
You can use Device Manager to install and update drivers for hardware devices, change the hardware settings for those devices, and troubleshoot problems.
Thank You,
John Major.
Hi Jackborn301,
The device Manage is tool in the operating system like windows 7.The most important function of this tool is to check whether your connected hardware device is working properly or not.
1.You can uninstall drives and roll back to a previous version of driver.
2.You can enable and disable connected hardware through this tool.
3.You can update for driver software.
4.You can scan for hardware changes.
5.You can check all the connected hardware devices to your computer.
