The device self test has failed.
I am exercising an NI PXI-5600 as the downconverter for an NI PXI-5661 vector signal analyzer that was earlier exercise as the downconverter for an NI PXI-5660 vector signal analyzer, while a self-examine in MAX shows a breakdown error code -200324. Some suggestions?
The device self test has failed. The error report from the device driver is as follows:
Error-200324 occurred at Self Test
Possible Reason(s)
Measurements : Device not available in NI-DAQmx. It is possible that the device is used by traditional NI-DAQ or that the device is been reset.
After using a device in traditional NI-DAQ, you must reset the device before using it in NI-DAQmX. For SCXI devices, you must reset the communacator DAQ device. Call the traditional NI-DAQ Device reset VI or the Init_DA_Brds function. To reset all devices in traditional NI-DAQ, right click the traditional NI-DAQ devices folder in MAX and select traditional NI-DAQ. If you are resetting the device, wait for the reset to complete.
OK
