Device setting not applied for an aggregate device in Audition
When creating an Aggregate Device in my Mac, Audition cannot attach, even though I’m only assigning the built-in microphone to it. From the audio hardware preferences screen, when I try to choose the Aggregate Device, Audition throws out this error:”The device in currently in use by another process”. I’ve tried closing every other program and tried assigning the device, but still the error persists. Can anyone please suggest what else I’m missing out and help me solve this problem? Thanking you for sharing your suggestions.
The device settings could not be applied because the following error
occurred:
The device is currently in use by another process. Close other applications
and attempt to select the device again.
The last valid device settings will be used.
