Dexpot 1.5.17 is One Good Software
The superb program, Dexpot 1.5.17 is very effective in making multiple virtual desktops.
So, how much RAM do I need to run this program smoothly?
The file size of 64 bit version of Dexpot 1.5.17 (dexpot_1517_r1991) is around 3.9 MB.
Once the program is installed it consumes 3600 KB of CPU as shown in below screen.
So, from the screenshot it can be observed that 2% of CPU is used when this program is running. Dexpot is used to create virtual desktops up to 20 and hence additional workspaces are created which occupies further memory.
The web says that RAM memory usage is increased by around 10% roughly when it is used more virtual environments which indirectly utilize more computer resources.
Hence it can be suggested that the minimum memory required for the system is 512 MB RAM. And to utilize this program for more virtual desktop environments, it is better to use systems with RAM not less than 1GB.
Charle Faru
Hi Nancyhernandyu,
Dexpot divide your monitor into 20 different virtual desktops.
Dexpot creates additional workspaces you can quickly switch between them.
Take, for example, Desktop 1 to listen to music, surf the web on Desktop 2, and use Desktop 3 to handle your daily word processing or switch to Desktop 4 for a game of Solitaire.
Different icons, wallpapers, startups, and much more can be configured for each desktop.
Minimum requirements run Dexpot 1.5.17
License : Free
Operating Systems: Windows 2000, Windows 7 (32 bit), Windows 7 (64 bit), Windows Vista (32 bit), Windows Vista (64 bit), Windows XP
RAM : 1GB or higher
Processor : PIV or higher
Hard disk space : 80 GB
It differs on which applications run on each desktop.
Best Regards,
Amanda Morson
