Sethanne
10 points
Posted on - 10/26/2011
My greetings to all!
Launching a file in Dynamics GP application through Dynamics.Set created this error. GP application won’t open properly and doesn’t offer any resolution to the error below. Does anyone know what to do to solve this error? I’m very grateful to all suggestions and help.
Dexterity Runtime
Data dictionary memory allocation error.
OK
Dexterity Runtime Memory Allocation Error
Hello Sethanne!
I'm sorry to hear that problem of yours. I've also encountered that problem before. I suggest you to rename the current reports.dic in your file and then re-launch dynamic. This will empty and new reports.dic file. Next is import all the reports from the renamed reports.dic file by going to Report writer. After I used this solution, dynamics GP application runs smoothly and no error encountered until now. I hope that it will also help you resolve your issue. I'll be glad if you will message me back and let me know if it is also worked for you. Have a good day and happy weekend.
-Zorian
To solve the error to your software is simply re-title the modern Dynamics. Set folder in the Dynamics/eEnterprise request file, and then simply Double-click the Dynamic.exe folder. After that just Press ALT+TAB or select Dynamics/eEnterprise on the taskbar to reach the minimized Dynamics/eEnterprise request, then select Folder – make Launch Folder. Receive the Dynamics. Set folder, and then simply verify the local Dynamics/eEnterprise request file and simply save it. Succeeding, it might prompt you to save the GENDDF.set, the Dynutils.set, or the tutorial. Set; click the Cancel when this is it pop-up to your screen.
Ben
